missfire
Old Feb 21, 2012 | 08:21 PM
michaelkirk150870's Avatar
4th Gear
Smile missfire
Hi
i have 2002 disco 2, i have a miss fire at low engagement and at 60kmh and over 100kmh.
I have checked
fuel pump pressure - good
compression tests twice - good
changed ht leads
changed plugs
no engine faults
now spent 700 bucks trying to find fault.
my best guess (and i am not the person doing the charging here) fuel injectors? any thoughts...getting to end of my patience. many thanks
Old Feb 21, 2012 | 09:09 PM
ALAKDisco's Avatar
What kind of plug wires did you put on the vehicle? I saw a set of 7mm wear out after less than 10k miles. I would go out at dark and spritz a little water on the plugs and see if I can see an arc. Worth a try and could save you a pile of money.
Old Feb 22, 2012 | 10:07 AM
4th Gear
Default missfire
Hi, they are Bosch. tried that no arcing, Gargare tested leads
4th Gear
sorry garage!
Old Feb 22, 2012 | 01:32 PM
aarongregor's Avatar
I was misfiring also after 2 new sets of wires and plugs and the problem was that one of the wires was burning up due to where I had it resting. When I moved the wire the misfire stopped.
Old Feb 23, 2012 | 09:21 AM
Michael, where are you located, I can call you and walk you thru what to check and do if you are not across the pond.
Old Feb 24, 2012 | 03:36 PM
4th Gear
Hi Mike
I am in NZ but i am happy to call you at a time suitable to you, can you email me your phone number? michael.kirk@epicure-nz.com
would appreciate your thoughts.
rovermike
Sep 30, 2009 03:39 AM
IDAHODISCO
Sep 17, 2009 08:54 PM
tee51397
Jan 22, 2008 10:58 AM
sailorcolin
Sep 11, 2007 08:00 AM
rovermike
Jul 3, 2007 11:56 AM
