missfire codes wont go away
Old Nov 16, 2009 | 02:23 PM
petedisco96's Avatar
Question missfire codes wont go away
I had P0300 and P1316, now P0303 I changed all the wires got no change was getting the code with the old wires. Plugs are stock champions pretty new. Do I have a bad coil pack on #3 . Idles good and runs ok but choppy and power loss at highway speeds around 50 mph on. Any Ideas thanks
96 Discovery 147,000 miles automatic
Old Nov 16, 2009 | 02:33 PM
Who's wires did you install, what octane gas are you using? Pull the number 3 plug and look it at, is it black, sooty and or wet, if wet, what does it smell like, gas or coolant?
Old Nov 16, 2009 | 03:45 PM
Default followup
It was black on the elecrode ceramic I tightened it down and it seems be running better less skipping. the other plug on the pack was normal looking. I dont know if that will clear all the codes or not. I used the STI wires this time blue silicon wires.
Old Nov 17, 2009 | 11:39 AM
same 3 codes are all back. what does a dry black plug indicate?
TRIARII
Apr 23, 2014 05:49 AM
Buzzwalburg
Oct 1, 2013 01:01 AM
richief556
May 29, 2013 01:46 PM
IDAHODISCO
Sep 17, 2009 08:54 PM
kevans
May 27, 2009 08:01 AM
