missfire on cyl5 at low idle
Old Jul 27, 2017 | 08:24 AM
me6067's Avatar
Default missfire on cyl5 at low idle
I cant figure this one out for the hell of me.
heres what I've done so far:
-spark plugs
-wires
-coil packs
-moved the injectors
When at low idles cylinder five miss fires, when at 1200+rpm there are no more miss fire counts on the graph from my diag tool.
What next?
Old Jul 27, 2017 | 10:33 AM
Dave03S's Avatar
Get a cheap boroscope and look inside the spark plug hole on 5. Look for any bubbles around the head gasket joint. If there are bubbles or signs of coolant you have a failing block. If there are none, you've ruled that out. Do this while the cooling system is still pressurized while the engine is still fairly hot.
Old Jul 27, 2017 | 10:49 AM
abran's Avatar
Also do it the next day after it has cooled down. When the engine is hot and it's just been running the coolant can all be burned out but if you let it sit in the cold it might sweat into the cylinder and you'll find it the next day
Old Apr 13, 2024 | 09:55 AM
me6067's Avatar
For anyone who cares this turned out to be an external head gasket leak into the valley. Exhaust gasses were blowing by. No coolant leaks or other heating.
walkingzach
Jul 11, 2014 01:47 PM
FRLNDR
Freelander
Jun 8, 2014 09:35 PM
franz
Jan 17, 2012 08:53 AM
EVN137
May 25, 2011 11:03 AM
Marty Mar
Jul 12, 2010 08:18 AM
