Missing zerk on drive shaft
The zerk was there after getting the d/s rebuilt. Are these plugs readily available? I don't remember seeing any with the zerks I found at Kragen. Another club member (who also has the plug) thought there was a possibility the zerk got knocked off by the cat. Even though there's not a whole lot of room, I would think a zerk wouldn't have clearance issues.
Yes they are readly available. All you need is to take a wrench and srew it in. If the orgininal wasnt in tight enough it could fall out, or if the clearance is close enough when the frame flex's and things move around it could knock the zerk out or break it off.
Poisonego2010
12-14-2010 07:20 AM
