Moaning noise
Old Jan 4, 2010 | 02:30 PM
  #21
SAI (secondary air injection) is a emissions thing.
The catalytic converters need to be up to temp to work, to speed them up getting to temp they force fresh air into them buy using a air pump.
It works like a blacksmiths bellows, he blows on his fire and it gets bigger and hotter to heat the steel he is working with.
The SAI on your truck does the same thing.
It gets noisy when the fitler to it gets clogged, it gets bad enough and it will stop working.
In the "how to" section there is a wrte up on how to replace the air filter to the SAI.
SAI is a good thing.
Old Dec 1, 2010 | 09:42 PM
  #22
landover's Avatar
6th Gear
Default Groan only in drive and stopped?
Hi, i'm new here and just wondering if anybody has a sound like this? I've been doing a lot of searching and this is probably the most similiar. It only happens after a long trip. I only hear it when in drive and stopped. As soon as I put it in park or drive away the sound goes away. I feel like it maybe rpm related since the rpms are lowest in gear and stopped. I'm thinking torque converter, power steering pump, or transmition. Any thoughts?
ammonation
Mar 19, 2015 11:37 PM
callmehero
Oct 17, 2012 08:07 PM
30more
May 28, 2012 05:01 PM
adrianwood
Freelander
Jun 13, 2005 08:53 PM
