Modest 2.5" lift on Disco 2 with ACE
Old Aug 15, 2020 | 02:29 PM
JeremyMCG1's Avatar
7th Gear
Question Modest 2.5" lift on Disco 2 with ACE
Background:
1999 Disco 2. Want to lift it 2.5 inches and put on larger tires.
  1. Purchased TerraFirma TF146 Pro Sport Shocks for Discoveries with a 2in lift.
  2. Purchased Supreme Suspensions 2.5" front and rear lift spring spacers.
NOTE:
1. The ACE System is fully functional and I want it to stay that way.
2. The rear air suspension is replaced with coils that are in perfect shape.
Question:
  1. Do I need to install sway bar extensions for a 2.5" spring lift?
  2. If so, what is the recommended extensions to get?
Old Aug 16, 2020 | 11:40 AM
JeremyMCG1's Avatar
7th Gear
Anyone?
Bueller?
Old Aug 16, 2020 | 01:31 PM
Best4x4's Avatar
No extensions are needed sway bar wise. If you really plan on flexing it out you'd want disconnects, longer brake lines, and extensions on the ABS Sensor wiring.
lndrover@carolina.rr.com
Jan 27, 2018 03:00 PM
bballjames
May 7, 2013 11:05 AM
RenoHuskerDu
Jan 7, 2012 05:17 PM
RenoHuskerDu
Oct 3, 2011 02:58 AM
khuds308
Aug 19, 2007 04:43 PM
