Modify thermostat
Old Sep 7, 2019 | 02:11 PM
jdbayer's Avatar
Default Modify thermostat
So I have an old thermostat and decided to cut it open and it looks like a normal thermostat. I found a 180 degree that fit in perfectly. I sealed it up and and am thinking of giving it a try. Has anyone does this? Last thing I want to do is damage my rover.
Old Sep 7, 2019 | 02:22 PM
OverRover's Avatar
IMHO, this is not a good idea.
True the thermostat is nothing special BUT the plastic housing uses a sonic weld to keep it water tight.
What did you use to seal the housing?
Old Sep 7, 2019 | 02:46 PM
jdbayer's Avatar
I used two types of adhesives. One inside that is more of a high temp gasket and then outside I used something we use on signs that weld plastics together.
Old Sep 7, 2019 | 03:00 PM
OverRover's Avatar
Sounds like a plan, I hope it works for you.
I think minimally I would rig up some caps and hoses to pressure test this experiment before it gets mounted to the truck.
Good Luck!
Old Sep 7, 2019 | 03:12 PM
jdbayer's Avatar
Good Luck!
Yeah, that’s what I was thinking.
Old Sep 7, 2019 | 03:51 PM
Best4x4's Avatar
Why not just buy a genuine 180F thermostat in the first place? I’d hunt down a real 180F britpart unit and call it a day for 30.00.
Old Sep 7, 2019 | 05:52 PM
jdbayer's Avatar
It was just something to do. I had the tools and the time.
flyingmada
Apr 26, 2018 06:42 PM
Luckyjayb
Apr 21, 2017 11:31 PM
huggi
Oct 12, 2016 11:09 AM
DiscoRover007
Aug 13, 2015 10:38 AM
VenVen
Nov 22, 2013 10:49 AM
