More codes
Old Jun 25, 2020 | 10:59 AM
merebel's Avatar
Default More codes
Ok so other than the two codes I have been getting p1173 and p044, I am now getting this since yesterday p0430 and p0153. Yesterday was very humid and a lot of fog. It is idle if rough also. I do have on order and waiting for delivery are new coil packs wires and plugs.
could be a vacuum leak ??
how do I make a diy smoke tester for this ?
also gas cap needs to be scotchbrite too as it hard to go in unless lubed with gas.
today cleared codes and haven’t come back yet low humidity and no fog.
Old Jun 25, 2020 | 11:55 AM
boston4's Avatar
Not sure on these ones but here are the descriptions for anyone else
P1173 Downstream fuel trim malfunction (bank 2) Front sensor aged - rear HO2S adaption too lean/too rich RH bank (NAS and EU-3 only)
P0440 Purge valve not sealing
P0430 - Catalyst efficiency deteriorated - RH bank (NAS and EU-3 only)
P0153 O2 sensor circuit slow response (bank 2, sensor 1) Front sensor aged - period time too long/too short RH bank
Old Jun 25, 2020 | 02:36 PM
Jason Feuerstein's Avatar
I would say that's more likely to be a dead o2 sensor and a bad purge valve.
Old Jun 25, 2020 | 03:13 PM
merebel's Avatar
Well then add that to the list :-(
Old Jun 25, 2020 | 04:02 PM
boston4's Avatar
Purge valve is pretty cheap - I think that @cvhyatt was having some issues with that code as well. Might be worth pinging him.
GregB83
Jun 4, 2020 03:05 AM
Freedom38
Aug 9, 2015 08:07 AM
Buzzwalburg
Sep 30, 2013 12:47 PM
lilherc
Nov 7, 2012 02:31 PM
Akumal
Oct 2, 2012 07:18 AM
