more misfires
Old Jan 21, 2013 | 11:06 PM
jeffh's Avatar
nothing on cyl 1, and the same codes after switching out coilpacks, plus Now I may be wrong, I do not have my coil pack sheet in front of me but I think cyl 3 and 5 are on different packs.. in any case it is driving me nuts...
Old May 1, 2013 | 09:55 PM
rtindle1975's Avatar
I have the same problem, and also codes for o2 bank 1 sensor 1. I replaced wires and plugs today and still have the problem. I am at a loss. could my o2 sensor be causing this problem?
Old May 1, 2013 | 10:13 PM
wires in correct spots?
Old May 2, 2013 | 01:33 AM
Yes, that is the exact diagram I used. Should note, the truck runs great most of the time, it just misfires at random times and seems to bog down for a few seconds and the SES light flashes then the truck runs great until it happens again, which could be 2 minutes or 10.
Old May 2, 2013 | 01:34 AM
Jeff did you get yours figured out?
Old May 2, 2013 | 07:40 AM
jeffh's Avatar
Rtindle, I did it ended up being a sticky lifter well 2 sticky lifters. As it was only happening at speed , i.e.over 50 mph. I went a did the BG engine pre oil change stuff and then added the BG oil additive. that seems to have fixed the issue. Right after I did the oil change, 3 weeks ago I hit the highway for 4 hour run to the mountains and had no issue. well once when I hit about 75, I was not paying attention and with a bunch of vehicles. but as long as I keep her at 65 no issues, in fact I got the best gas milage I have ever gotten on that trip. I do not run this truck very much only about 5-6 hundred miles a month so sometimes it takes me awhile to get around to the final fix or reposting. You said you changed your wires what brand did you use. and what size.
Old May 2, 2013 | 01:30 PM
I bought new coils last night and o2 sensor. I will happily pay the restocking fee if this works, I am going to buy the BG pre change stuff now. Thanks alot for the info Jeff.
Jordanmd88
Jan 9, 2012 05:56 AM
Bryan H
Feb 12, 2009 10:59 PM
japt29
Jul 19, 2007 09:24 AM
hendoc3
Jul 18, 2007 03:10 PM
whodey
Mar 6, 2005 01:49 PM
