mot
Old Nov 7, 2022 | 10:34 AM
chippycars's Avatar
Default mot
my horn does not work, fuses are ok relay clicks and ibhave also tried other relays but no voltage at horn end is there any joins in the middle?.
i also have a problem with the headlight adjusters they dont work and it has failed the mot on them also. can any body help?
Old Nov 7, 2022 | 10:46 AM
greisinb's Avatar
You may want to check the horns themselves- the "trumpet" of the horns (there are two of them) open up facing forward as one would expect. The are just behind the grille so rain/dirt/debris/etc. can get in pretty easy. I had the same issue and replaced both of them with some aftermarket Hellas mounted on a simple bent metal bracket I made.
Old Nov 8, 2022 | 08:54 AM
sqlbullet's Avatar
I recently went through my headlights and replaced broken adjusters. I got parts from Atlantic British, though Amazon had them too.
chippycars
Nov 7, 2022 10:36 AM
babyxbuffalo
Jan 8, 2016 11:55 AM
Southern Bawb
Apr 18, 2015 05:57 PM
jw928
Jan 4, 2011 07:29 PM
Russian_Rover
Nov 4, 2010 06:09 PM
