motor mounts on disco II
Old Feb 7, 2008 | 04:27 PM
aublec22's Avatar
Default motor mounts on disco II
ARE THE MOTOR MOUNTS REALLY MADE OF RUBBER ?? IS IT REALLY TRUE THAT THEY ARE REQUIRED TO HOLD THE ENGINE IN PLACE SO THEY CAN TAKE OUT THE OLD TRANNY? THE MECHANIC SAID RUBBER AND GLUE.
Old Feb 7, 2008 | 05:33 PM
Default RE: motor mounts on disco II
Is this a surprise to you??
Nealy all motor mounts are made of rubber and some sort of a metal backing plate.
No they are not designed so you can remove the tranny, boy your mechanic needs to gather up his little red tool box and start selling apples on the corner.
All engines are mounted to the fram of a vehicle as is the tranny, other wise when you speed up it would jump right out of the engine compartment.
Old Feb 7, 2008 | 06:01 PM
aublec22's Avatar
so is false when he says to me that they can't take out the tranny til the mounts arrive ? he said mine were in need of replacing and that those had to come in bofore he could remove the old part.
Old Feb 7, 2008 | 06:09 PM
They can pull the tranny if they have to, the weight of the engine will hold it in place.
vandev
Jun 16, 2025 07:54 AM
FlyingZebra34
May 3, 2012 09:17 AM
FlyingZebra34
Apr 27, 2012 04:33 PM
Willie00d2
Feb 17, 2010 09:49 AM
btbaus
Nov 16, 2009 01:40 PM
