Motor torque question.
Old Mar 16, 2012 | 07:02 AM
innzane's Avatar
Default Motor torque question.
For a head job, on the 4.0 rover engine. For the head bolts and torque-ing them down. What size ratchet drive is most commonly used?
Should I pick up a 3/8" or a 1/2" drive torque wrench?
Also I found the odd rocker cover bolts that need a special socket. Any heads up for any more suprises like that? I am pulling heads and oil pump.
Thanks and have a great weekend, weather is nice.
P.S., it's ripped down to the intake manifold now.
Old Mar 16, 2012 | 08:38 AM
ralphobell's Avatar
Use the 1/2 torque wrench, Rocker cover bolts use an 8MM 12pt Socket.
http://www.lowes.com/pd_338089-25428...ket&facetInfo=
Old Mar 16, 2012 | 08:59 AM
Plan on buying a impact socket for the head bolts.
Had you ever done this before, do you have a shop manual or Rave and where sre you buying your parts from?
Old Mar 16, 2012 | 04:22 PM
innzane's Avatar
Do you mean just the impact socket to use on the torque wrench? For the 2 90* turns after the initial torque.
I have never done this on an aluminum block.
I do have the rave.
Parts will be from who offers the lowest price, probably on of the Ab sites or the guy in your siggy.
Plan right now is the top end gasket set, hose set, oil and water pump gaskets. Rest of the stuff I want to inspect before commiting to, like the cam, cats, O2 pump etc.
Old Mar 17, 2012 | 06:12 AM
antichrist's Avatar
OTC 4554 (or similar)
As for a torque wrench, 3/8" is fine (in the right torque range) for the head bolt initial torque. And for the exhaust manifold's, etc. But you may find a 1/2 more useful later on for other things.
Old Mar 17, 2012 | 10:13 AM
Rovin4life's Avatar
the head bolts are a very low number so you need a 3/8 but it pays to have a cheater bar and a long half inch socket and wrench to do the job.
the crankshaft bolt is 250lbs that is the one you need for the 1/2 inch torque wrench for.
You do have to pull the oil pan to get the timing cover off and you need to pull off the front steering bar out of the way and raise the vehicle to get it out. other wise the rear bar comes off and it needs to get torched out.
Old Mar 17, 2012 | 12:09 PM
innzane's Avatar
Thanks for that tip, I did not know that either.
Pratice picture
1999SE40
May 16, 2014 06:48 AM
me 2
Jun 17, 2012 07:24 PM
elrocha69
Jan 16, 2012 06:50 AM
ColeRover
Feb 9, 2011 07:05 AM
