Moved Handbrake
So I was tired of my leg hitting the handbrake and while working on the CDL I noticed that the setup could easily be flipped. It is a simple process.
1. Remove center console
2. Remove hand brake
3. Unplug all connectors to Transmission ECU
4. Reroute harness to RH side of console
5. Reroute e-brake cable to right side (easy to do from under vehicle)
6. Reconnect connectors to Transmission ECU
7. Install hand brake
8. Install center console
Sorry did not take pictures while doing this. But it is really simple and once you have the console out you will see. If your not 6'5" and 300lbs, then you might not even care. But when driving all day in this like I do, I really get tired of the e-brake handle jamming me in my thigh.
JUKE179r (11-12-2017)
Great little mod!
