Moved Handbrake
Old Mar 16, 2013 | 11:06 AM
ralphobell's Avatar
Default Moved Handbrake
So I was tired of my leg hitting the handbrake and while working on the CDL I noticed that the setup could easily be flipped. It is a simple process.
1. Remove center console
2. Remove hand brake
3. Unplug all connectors to Transmission ECU
4. Reroute harness to RH side of console
5. Reroute e-brake cable to right side (easy to do from under vehicle)
6. Reconnect connectors to Transmission ECU
7. Install hand brake
8. Install center console
Sorry did not take pictures while doing this. But it is really simple and once you have the console out you will see. If your not 6'5" and 300lbs, then you might not even care. But when driving all day in this like I do, I really get tired of the e-brake handle jamming me in my thigh.
Attached Thumbnails Moved Handbrake-2013-03-16_10-50-47_492.jpg   Moved Handbrake-2013-03-16_10-50-35_235.jpg
Old Mar 16, 2013 | 11:16 AM
Cool. I suppose that is part of the LHD or RHD configuration of the vehicles.
Old Mar 16, 2013 | 01:33 PM
ralphobell's Avatar
You are correct Savannah.
Old Mar 16, 2013 | 10:10 PM
Bkreutz's Avatar
That is a slick discovery (pun intended) ranks up there with flipping the spare tire carrier upside down for oversize tires.
Old Mar 16, 2013 | 10:38 PM
taylor15's Avatar
Nice mod. One of those things no one will ever notice if you don't tell them.
Old Mar 16, 2013 | 11:18 PM
jfall's Avatar
Well done.
If you move the cluster, steering wheel and pedals then I think you are ready for the UK.
Actually, there may be MORE ROOM on the right side as this Discovery was probably designed to be at home in Britain.
But, hard to say without measuring it all out.
Old Mar 17, 2013 | 09:00 AM
nychaze's Avatar
Originally Posted by jfall
Well done.
Never thought of that but i bet you are right...the passenger side floor area seems much more roomier...
Great little mod!
Old Mar 17, 2013 | 11:45 AM
ralphobell's Avatar
In this case it was for an oversize Man!
Old Jun 1, 2014 | 06:39 AM
OffroadFrance's Avatar
I believe you are dead right Savannah. The body shells and many parts appear to be 'universal' and can be configured later for RHD or LHD. It appears very few parts are specific orientation.
Old Jun 3, 2014 | 02:14 AM
Richard Moss's Avatar
Transfer box offset to one side? This is why there are usually different spring rates left/right
