Moving to Cold Weather w Disco2. Please help w tips to keep Disco alive
Old Feb 1, 2021 | 02:01 PM
Armando's Avatar
Originally Posted by greisinb
Make sure your coolant (and washer fluid!) is mixed properly for sub zero weather. In Florida you can get away with running a weak mix but not so up there!
Signed,
A former resident of the Midwest.
oof. Didn't even think of the washer fluid!
Old Feb 1, 2021 | 05:11 PM
Extinct's Avatar
Coat the frame if you are going to be in salt season. Use the Rustoleum rust converter first, then fluid film over that. Inside and out. Get the Eastwood frame spray nozzle tube and spray it inside the frame as well. Your factory bumpers, cowl, and A pillars will likely crack from the temperature extremes and the resulting thermal expansion. Vinyl wrap the A pillars if you want, coat the cowl with the rattle can bedliner spray on the front, if you want you can coat the back with linex or Rhinoliner or some other polyurea bed spray to increase the strength. You can use expanding foam from home depot on the back side of the bumpers to help. No guarantee though, they will still likely crack.
Old Feb 1, 2021 | 05:39 PM
greisinb's Avatar
They sell "winter formula" washer fluid, I don't know if its stocked regularly in Florida but it's probably something you could order on amazon until you are able to hit up a Walmart further up north.
Old Feb 2, 2021 | 12:23 AM
JUKE179r's Avatar
Get a long handle ice scraper/brush and good Breakdown recovery company like AAA or the like.
mudpuppy229
Feb 1, 2017 03:07 PM
MeanSaleen
Sep 13, 2013 12:37 PM
Rover Reaver
Nov 2, 2008 12:23 PM
Rover Reaver
Oct 31, 2008 10:09 AM
kumbhani123
Apr 15, 2005 02:46 PM
