Moving to Fairbanks Need Help
#21
Another option, which makes you independent of power outlets, is a gasoline operated heater. It is connected to your coolant system and heats the block as well as the interior (it turns on the interior fan as well). It has a timer and a remote control can be added optionally. I had such a heater when living in much colder climates. But even in normal climates, where it can get below freezing, it reduces engine wear and improves fuel economy. You never have to start a cold engine anymore, the engine gets heated up to about 120F, windows are defrosted and it is warm and cozy inside already, when you get to the car. It's also a nice feature when you do a lot of outdoor activities in winter.
https://www.ebay.com/itm/New-Webasto...r/273505505318
#22
This is pretty easy :
- Block heater is a very good idea
- Oil pan heater is 50/50 if you have a good block heater it is not generally required
- Oil change will be required -cold weather grades generally 5/30 according to the RAVE for down to -20
- Anti-freeze should be changed out - check recommendations for northern environments usually 50/50 is sufficient of a good anti-freeze. Going to higher concentrations can impair engine cooling
- Battery replaced if it is at all doubt full
- Wiper blades replace with cold weather units
- And real snow tires - possibly studded
#23
this is but I would go with a 0w-40 oil.
Banzai Jimmy (11-22-2019)
