Moving to Fairbanks Need Help
Old Oct 29, 2019 | 01:30 PM
  #21
Discorama's Avatar
Another option, which makes you independent of power outlets, is a gasoline operated heater. It is connected to your coolant system and heats the block as well as the interior (it turns on the interior fan as well). It has a timer and a remote control can be added optionally. I had such a heater when living in much colder climates. But even in normal climates, where it can get below freezing, it reduces engine wear and improves fuel economy. You never have to start a cold engine anymore, the engine gets heated up to about 120F, windows are defrosted and it is warm and cozy inside already, when you get to the car. It's also a nice feature when you do a lot of outdoor activities in winter.
https://www.ebay.com/itm/New-Webasto...r/273505505318
Old Nov 21, 2019 | 04:29 PM
  #22
enb54's Avatar
Originally Posted by Richard Gallant
This is pretty easy :
  • Block heater is a very good idea
  • Oil pan heater is 50/50 if you have a good block heater it is not generally required
  • Oil change will be required -cold weather grades generally 5/30 according to the RAVE for down to -20
  • Anti-freeze should be changed out - check recommendations for northern environments usually 50/50 is sufficient of a good anti-freeze. Going to higher concentrations can impair engine cooling
  • Battery replaced if it is at all doubt full
  • Wiper blades replace with cold weather units
  • And real snow tires - possibly studded
As a former denizen of the obsolete DEW Line, I can vouch for this stuff, on your drive to Alaska through Canada you'll get a taste of the weather in Eielson. If you can possibly get housing with an attached/heated garage that is a really good thing to have in cold climates, the timer for the block heater is also a good idea. No doubt you have researched your posting quite a bit, so I needn't remind you of only 4 or so hours of daylight in December and January...
Old Nov 21, 2019 | 08:08 PM
  #23
redwhitekat's Avatar
this is but I would go with a 0w-40 oil.
masterseung
Jun 7, 2014 09:24 AM
Slingin Carbon
Dec 10, 2012 08:09 PM
Phoenix_522
Nov 28, 2012 10:37 AM
Disco2Fever
May 5, 2010 01:13 PM
kumbhani123
Jun 6, 2005 02:21 PM
