Multifunction Controls on Steering wheel stopped working
Hi Guys
Wondering if anyone can help with this problem.
At the weekend i changed the power steering box, once it was all back together the steering wheel functions ie: Volume control, horn, cruise control all stopped working. I have done some investigating, a little blindly if honest, but cant find the answer.
I have a theory that when we was trying to reconnect the steering wheel linkage to the power steering box there was allot of pulling and banging trying to get it reconnected. it took three attempts to get it connected so the steering wheel was straight, and i was wondering that i might have confused the ecu to thinking that the car had hit something, which in turn has caused the SRS light to come on and stay on. From what i have read there is talk of a pin in the steering wheel housing that may of popped out and needs to be reset.
Has anyone got any ideas or help.
thanks
thanks
Thanks Mike.
i have spoken with my local garage after your reply and he advised me that there is a circuit board under the steering wheels, and he thinks that i have broken this during the process of changing the power steering box. He is going to plug my car into the machine which will verify this. Fingers Crossed. Thanks for your help i will let you know how it goes
Cheers
Shane
Cheers
Shane
Thanks Mike.
Cheers
Shane
Cheers
Shane
Did you hav any luck av had the same problem please help
The rotary coupler can be damaged by moving certain parts when working on steering issues. Please read these three pages from the RAVE. Always a good idea to review the shop manual.
For the radio controls, reading with an ohm meter across the gray with red and the gray with black wires should show "open" if no buttons pressed. When pressed, the resistance will be between 0 and 3600 ohms, depending on what was pressed.
tsuyoi
Sep 22, 2020 10:37 AM
caneraiser
Oct 27, 2012 07:35 AM
