multiple atempts before starting
hi all, I recently purchased a 97 disco an noticed that it takes several cranks to start , sometimes 10 or more atempts (breaks in between each atempt so not to kill starter or NEW battery) replaced plugs and wires no change. I also hooked up my obd and came up with code p1317 (abs) code p1193 oxygen sensor hearter open downstream . I was guessing the o2 sensor was maybe showing up because of a possible converter problem(maybe getting plugged up) could that also be a problem in starting. Also after starting in the morning it starts fine for 5 or 6 hours then back to the hard starting. I live in southwest arizona cold temps are not an issue even when its in the 80s I have the same problem. Thankyou for any input.
RE: multiple atempts before starting
Your O2's are bad but they will not cause hard starting. I think your hard starting is a bad fuel temp sensor. And being in AZ it would be hot longer/more often.
http://www.roverparts.com/TechTips/h...t_problems.cfm
ORIGINAL: Spike555
try replacing the hose from the intake to the valve covers i think the air induction hose and putting hose clamps on it mine did the same thing i replaced the fuel filter didnt help so looked up and the possible cause was a vaccum leak that happens when the engine gets warmed up it work start and will turn off at idle or sitting at stop light
on
ORIGINAL: Desertrat45
Thanks mike, will give it a try. I was told all filters were just replaced, but I did buy my disco in a small used car lot. would the o2 sensor (code p1193)become a problem being downstream? Hope it is the filter love the easy fix. thanks
303-862-7680
Colorado before 8 pm
