multiple atempts before starting
Old Apr 18, 2008 | 11:34 AM
Desertrat45's Avatar
7th Gear
Default multiple atempts before starting
hi all, I recently purchased a 97 disco an noticed that it takes several cranks to start , sometimes 10 or more atempts (breaks in between each atempt so not to kill starter or NEW battery) replaced plugs and wires no change. I also hooked up my obd and came up with code p1317 (abs) code p1193 oxygen sensor hearter open downstream . I was guessing the o2 sensor was maybe showing up because of a possible converter problem(maybe getting plugged up) could that also be a problem in starting. Also after starting in the morning it starts fine for 5 or 6 hours then back to the hard starting. I live in southwest arizona cold temps are not an issue even when its in the 80s I have the same problem. Thankyou for any input.
Old Apr 18, 2008 | 12:20 PM
7th Gear
Default RE: multiple atempts before starting
Also had a code p3999 which i have seen other people asking about, I don't think its a code for a problem maybe the reader telling me end of codes?
Old Apr 18, 2008 | 01:21 PM
7th Gear
Could the starting problem be the fuel pump. I really would of thought after a month of this problem every day the pump would have all together stop working.
Old Apr 18, 2008 | 02:05 PM
When was the last time you replaced your fuel filter.
Do that next and then after it has sat for a while see if there is any fuel pressure left in the rail, if low, you will need a new fuel pump.
Old Apr 18, 2008 | 02:29 PM
7th Gear
Thanks mike, will give it a try. I was told all filters were just replaced, but I did buy my disco in a small used car lot. would the o2 sensor (code p1193)become a problem being downstream? Hope it is the filter love the easy fix. thanks
Old Apr 18, 2008 | 03:52 PM
No, that is an oxygen heater circuit down stream is out, won't cause what you are describing.
By the way, the gas filter is bolted to the r/r wheel weel are and is hard as hell to replace, will take lots of penatrating oil.
Old Apr 18, 2008 | 06:16 PM
Your O2's are bad but they will not cause hard starting. I think your hard starting is a bad fuel temp sensor. And being in AZ it would be hot longer/more often.
http://www.roverparts.com/TechTips/h...t_problems.cfm
Old Apr 18, 2008 | 06:20 PM
Landzu's Avatar
ORIGINAL: Spike555
This is what it sounds like to me also.
Old Apr 18, 2008 | 10:19 PM
rwarren92's Avatar
try replacing the hose from the intake to the valve covers i think the air induction hose and putting hose clamps on it mine did the same thing i replaced the fuel filter didnt help so looked up and the possible cause was a vaccum leak that happens when the engine gets warmed up it work start and will turn off at idle or sitting at stop light
Old Apr 19, 2008 | 08:20 AM
ORIGINAL: Desertrat45
Do the filter this morning and then call me, I'll walk you thru a simple test to see if it is then the pump.
303-862-7680
Colorado before 8 pm
