Multiple Codes
Old Dec 10, 2015 | 01:18 PM
CollieRover's Avatar
Default Multiple Codes
Hi Guys,
I am getting ready to head up to MPLS from Chicago for the Holidays and do a laundry list of stuff to my DII. I am leaving Sunday, and got the following codes the last couple of days.
P0160 - No activity Right Bank o2 sensor came on.
I sprayed some soapy water on the exhaust manifold passenger side yesterday to see if I could detect some leaks. I put some dye in to test the cooling system for leaks last night, test drove it to Menards today and get the following codes.
I also filled up at Costco with 93 Octane, first time.
P1319 - misfire detected with low fuel level
P1300 - Random Multiple cylinder misfire
P0302, P0304, P0308, P0306, these are all cylinder misfires 2,4,6, 8 misfires
What I am wondering is if me spraying soapy water and getting into the spark plugs could cause this, bad gas from Costco, or if I should swap out the O2 Sensor prior to a long drive on Sunday.
What would you guys do?
Old Dec 10, 2015 | 01:21 PM
Broken08's Avatar
for sure I'd start by drying the wires and reset the codes.
Otherwise I'd be thinking the O2 sensor and/or wiring are bad.
Old Dec 10, 2015 | 01:28 PM
dgi 07's Avatar
Replace the O2 sensor. Clean the wires and plugs tips with contact cleaner. Then a dab of dielectric grease and be on you way.
Old Dec 10, 2015 | 01:34 PM
Thanks guys. i will grab a new O2 sensor.
Old Dec 10, 2015 | 02:04 PM
OReilly's will have my new 02 sensor today. The Spark plugs and wires were perfectly fine.
Old Dec 11, 2015 | 03:10 PM
I got the new O2 sensor put in and just after install there were a couple more misfires, same side. I am going to wait and see what happens on a test drive tomorrow. The P0160 definitely meant I needed the O2 sensor and I am hoping/guessing that is what the misfires were.
Next I would think Coilpack would be the obvious culprit as the misfires are all on the passenger side.
The muffler guy who got the O2 sensor out in about 5 minutes let me know the rest of my exhaust is good. I was planning on changing it out, but aside from looking like crap it's ok. So, new bumpers it will be.
Old Dec 11, 2015 | 03:58 PM
dgi 07's Avatar
New coil isn't it. One coil doesn't doesn't control an entire bank of cylinders. http://www.wicasta.com/blogs/wp-cont...iscoveryIC.jpg
Clear the codes and drive it.
Old Dec 12, 2015 | 02:20 PM
Drove around all morning, and no codes, so am going to head to Minneapolis from Chicago tomorrow. Hopefully, all goes well. When I get there the brakes, and cooling system are getting overhauled and the oil pan is getting a new gasket.
madsjr
Freelander
Aug 17, 2011 08:09 AM
mcgyver210
Feb 11, 2011 08:55 AM
timdunbar
Oct 2, 2010 07:06 PM
boldingm
Mar 15, 2010 05:59 AM
2000 DII
Aug 22, 2008 10:28 AM
