mushy brake pedal
mushy brake pedal
Is this the "shuttle valve" problem? Rover did some work on a "overlay harness" and I'm not sure if this is related to the Shuttle valve or the "wheel sensor?"
The pedal felt great on the vehicle after I got it from Rover and then a few months later the lights came on and the pedal went mushy.
Aftermarket brake kit on the vehicle btw...
Thanks guys!
Thanks guys!
RE: mushy brake pedal
I would suggest the old 2 man method. starting with the furthest away, making your way closer. Keep pumping until new fluid comes out.(and drain the master with a turkey baster and fill with new fluid first). I have heard of too many people using power bleeders and them not working right.
