mushy direction
Old Mar 27, 2010 | 12:11 PM
EL GALLO's Avatar
Default mushy direction
Hello Guys
MY 05 LR3 had a leaky rack an pinion ,so I changed it and replaced some bushings,and installed new tires,but I now notice steering is kinda of mushy and not tight and precise as before.Any reason this is so?I thought it would improve the feel of the steering, but it is not the case.Thank you in advance for any suggestions that can solve this.
Old Mar 27, 2010 | 05:04 PM
Scott R's Avatar
Mushy as in laggy? In lag from the time you turn the wheel until the time the tires start to move?
Old Mar 27, 2010 | 05:47 PM
EL GALLO's Avatar
yes and it kinda wanders a bit and has to be corrected more often than usual.Thanks for reply.
Old Apr 21, 2010 | 03:33 PM
safarisam's Avatar
could be some bubbles in the system... did you install it or did you have it installed?
Old Apr 21, 2010 | 05:26 PM
CopperMtnGuy's Avatar
I agree with SafariSam...
Did you re torque the bolts after you drove it? Might want to also make sure everything is nice and tight.
Keep us posted.
Old Apr 21, 2010 | 10:10 PM
EL GALLO's Avatar
Had it installed and it was just that air bubbles now it is fine.thank you for your help!
asmcmillin
Jul 2, 2023 04:25 PM
jrm123180
Nov 16, 2011 10:33 AM
bcolins
Oct 11, 2008 08:23 PM
kraelo
Apr 1, 2008 12:02 AM
ryanrover
Dec 5, 2007 07:19 PM
