must the fan come off for a belt change?
Old May 30, 2019 | 10:41 PM
Ben Matheson's Avatar
Default must the fan come off for a belt change?
Watched the AB video and they took off the fan. Does it have to come off? I don't have the tool and trying to save a trip to rent one.
Old May 31, 2019 | 01:14 AM
Brandon318's Avatar
I think not, but the shroud for sure does.
Also, I've never needed the actual tool set, just an appropriately sized open-end wrench (36mm?). The friction of the belt in addition to a quick hit with a rubber mallet on the wrench loosens it right up.
Old May 31, 2019 | 06:27 AM
JUKE179r's Avatar
No you don't have to remove the fan. Pay attention how you take it off tho...
Old May 31, 2019 | 08:22 AM
CollieRover's Avatar
Juke is correct. You can loop it around the fan be just fine. Taking off the Viscous fan clutch is a pain in the neck, I don't miss it in the least.
Old May 31, 2019 | 10:22 AM
Best4x4's Avatar
You can do it. With the fan in place, but with it removed it’s like a 2min job. I now have a large 36mm open end/box wrench. Place it so it’s straight up, hit it with a small sledge & it should break free. I’ve only had one D2 be a PITA to remove & it was due to rust. All my personal LR’s = come right off.
Old May 31, 2019 | 11:13 AM
Big Jim Swade's Avatar
The fan is so easy to remove, you really should remove it.
Old May 31, 2019 | 02:43 PM
mln01's Avatar
I bought a fan wrench from Northern Tool for ~$15. Good purchase.
Old May 31, 2019 | 03:55 PM
Best4x4's Avatar
I got the 36mm box wrench from northern tools! No more bending the thin 36mm tools open!
Old Jun 1, 2019 | 09:56 PM
Discorama's Avatar
I took the fan off many times, it was very easy. I got the 36mm wrench on ebay for $15. I slide the wrench in and hit the end with a hammer. It always gets unlocked of after the second hit latest.
Zelatore
Dec 28, 2017 10:56 AM
sharp
Dec 16, 2013 11:35 AM
flanker6
May 26, 2013 10:48 AM
rrhyne
Jun 8, 2010 09:13 AM
1stshift
May 5, 2009 04:11 PM
