My 4.0 V8 Overhaul/Rebuild Thread - MY2002 107k
Old Jul 30, 2016 | 09:12 PM
Jeff Blake's Avatar
Quick update.. still in dismantling and cleaning phase.
- took apart the rocker shafts, cleaned them. Plan on keeping the supports, bolts, and washers as long as they're still in spec on the new shafts. Still need to source rocker arms. I'm thinking turner engineering or v8tuner, both in UK.
- Cleaned the timing cover, oil pickup, oil cooler hose. Permatex gasket remover and purple power are the winners here. Heck, the gasket remover stuff is so good, I use it for hard to remove varnish as well.
- Took a stab at sandpaper-wheeling the exhaust manifolds with a dremel. Kind of works... but I burned through all my wheels really fast. Wish I had a better tool for this. Would like to get it sand blasted and ceramic painted in a furnace.. but on a budget. I also have Loctite Rust Naval jelly ... hmm didn't seem to do much. I think sand paper is going to be the only thing that works here
- box of old parts on their way out
- y-pipe is super rusted. The flange especially. Don't know what I'm going to do here yet. At a minimum it needs new studs and nuts. Magnaflows or whatever would be cool... but Im thinking lets get this rover running again first
Next up... pulling the block. It's ready to pull, need a hoist. I can rent a hoist for $34/day or buy the harbor freight one for $180 and sell it when done for ~$100. $34x2 for renting (not factoring if I have issues putting it back in and need it longer)... for piece of mind I think I'll buy the HF hoist and work at my leisure.
Following the block pull, I'll be spending a lot of time inspecting everything, measuring tolerances, etc as per the rave overhaul manual.
Old Jul 30, 2016 | 11:56 PM
Mskembo's Avatar
Looks like you're doing things correctly! Keep it clean! can't wait to see you digging deeper.
Old Jul 31, 2016 | 11:12 PM
Jeff Blake's Avatar
Pulled out the engine harness (will need to redo some loom, some sections crumbled in my hands). Engine is now 100% ready to pull. Ordered a hoist from Harbor Freight for $135 + 6$ shipping.
Engine stand came today... was missing the lock pins for the wheels Oh wait... the pins from the old rocker shafts worked perfect! Ha.
I'm considering ordering a micrometer and dial bore gauge to take all the measurements myself and save on shop work. Same with valve springs & seals - thinking I might do this myself. Resell the tools after. Any opinion on this? It doesn't look like rocket science to me. I like to have my hands on everything. This way - assuming everything is in spec - I can limit shop work to installing the cam bearings, and maybe a crank polish if needed. If valves need grinding, cylinder needs boring, decks surfaced, crank turned.. etc.. then yeah that goes to the shop.
Old Jul 31, 2016 | 11:25 PM
Mskembo's Avatar
I believe in buying tools, because I end up using them more than once. Usually the thing that keeps me from tackling a project is not having the right tools, so the more tools I have the happier I am to dive into a project. Be it my own or helping out a friend.
Old Jul 31, 2016 | 11:59 PM
abran's Avatar
Leave the head work to professionals. If something doesn't turn out right you will be second guessing your work.
Old Aug 1, 2016 | 10:02 AM
evoblade's Avatar
I'm considering getting a stud puller like the one you guys linked. Do they damage the threads? I was planning on replacing some of the goofy studs on the intake manifold with bolts, but there are others I would like to pull and I wonder if I will be able to reuse the studs.
Old Aug 1, 2016 | 10:51 AM
Fast951's Avatar
Many stud removers damage the threads. Have you tried the double-nut trick? Run two nuts onto the threads and then tighten them against each other. Then put an open end wrench on the inside nut and see if the stud will back out.
Old Aug 1, 2016 | 11:01 AM
zuke's Avatar
What about the sleeves? Top-hat those things
Old Aug 1, 2016 | 11:47 AM
Jeff Blake's Avatar
Top hats would break the bank. And I don't think this block has ever overheated.
re stud puller - the threads actually looked good - but I wouldn't reuse them. I took off the intake manifold studs as well months ago.. but those come off easily with vice grips. Picked up bolts from the hardware store.
Atlantic British says the grooves in the cam bearings is by design for better oil flow. Hmm. I'm going to take these $155 bearings back anyway, and get a set from Turner Engineering in the UK for only $30... along with main, rod, and other stuff I'll need. I have a good feeling about Turner. I have no idea why the bearings in the states are all so much money.
Also thinking to get Turners performance H180 Camshaft Sports Torque. Wonder how it compares to a Crower?
Old Aug 1, 2016 | 01:05 PM
Mskembo's Avatar
It's because the Rover V8 is the British equivalent of the small block chevy here in the US.
