My Brake Job
Old Oct 23, 2008 | 11:19 PM
gregmraymond123's Avatar
Default My Brake Job
So I recently bought a 98 discovery. Drove it all over the place and I friggin love it. Day comes when I need to go over the mountians to go to a concert, so I take the truck. To make a long story short, the brakes didn't make noise at all before the trip, but by the time I got home, one of them had burned a groove into one side of a rotor. Call me what you will... The reason why I'm posting this is due to the fact I couldn't really find anything on how to pull the hubs. Tidbits here and there... I bought a Bentley Manual, what I got from this site, other sites, other manuals on other cars, advise, and I replaced my front rotors and regreased my wheel bearings. I thought at the least I should share my pics with my fellow land rover owners who might need them. I find out now the pics are too big and I'm out of time. Will put up in edit
Old Oct 24, 2008 | 07:45 AM
Default RE: My Brake Job
So you got the job done then?
Pics would be awesome.
I use www.photobucket.com, copy the dirct link then click the little mountain on the post box, paste your link and BAM!, you have a pic on the forum.
Old Oct 24, 2008 | 01:20 PM
Willie 00D2's Avatar
Just don't do what my neighbor did. He put his new brake pads on backwards. Metal on metal. Time for some new rotors and pads.
Willie
Old Oct 24, 2008 | 09:25 PM
AK Rover's Avatar
I actually just ordered new pads and rotors for my D1. I have a Haynes manual and it has pretty good instructions on what needs to be done. That being said, I can't really get a true grasp of how big the job is going to be just by reading through the instructions. Hw long did it take you to do the work? Did you need any specials tools do complete it?
Any input is appreciated. Thanks
Old Oct 25, 2008 | 07:29 AM
redhotbuzz's Avatar
While your in there you might as well relace bearings and rear hub seal..The hardest part of the job for me was taking old rotor off thehub..Be careful with the calipers or you will be replacing brake pipe as well,,,Looking back I wish I
would have replaced rubber hose with stainless flex, Its not really a bad job though..This helped me,,,,http://www.4x4wire.com/rover/mainten...heel_bearings/
Old Oct 25, 2008 | 07:32 AM
redhotbuzz's Avatar
BTW AK we got the same rover ,,,Except some one clipped my lights at the auction house,,
Old Oct 26, 2008 | 04:50 AM
Adz's Avatar
Adz
Taking the rotor off the hub: Put the wheel you've taken off face down on a mat. Put the wheel studs of the hub through the holes in the wheel. Sit on the tyre with a breaker bar and socket in hand. Undo the bi-hex nuts holding the rotor on - piece of cake
Old Oct 26, 2008 | 09:39 AM
redhotbuzz's Avatar
good tip Adz ... the only reason I said the rotors were hard to remove was that they were frozen on the hub and it took some ball bean persuasion to get them apart
Old Oct 29, 2008 | 07:55 PM
anonimaus's Avatar
When I redid mine awhile back, I used the combination of a good mallet and liberal soaking with PB Blaster penetrating oil.
jroy
Apr 21, 2012 06:42 PM
EuroStyle
Feb 20, 2011 09:40 PM
ciocc
Jun 8, 2007 11:11 PM
Landdaddy
Jun 8, 2006 03:34 PM
surf9ska
Feb 14, 2006 03:52 PM
