My compression test results 😔
Old 08-04-2016, 05:31 PM
DiscoBuckeye's Avatar
Default My compression test results 😔
1=180 3=150 5=140 7=170 8=30😳 6=180 4=160 2=180
Put a bit (ok too much I think) of oil in #8 to test if it was the rings. Initially it jumped to 200 and would drop back to 30 after cranking. After I got much of the oil out it would mostly go from 90 and sit at 30 after cranking. My compression gauge does have an O ring btw.
Head gasket for sure?
Old 08-04-2016, 06:46 PM
abran's Avatar
The "for sure" test would be a leak down test. You know you have a problem on 8, but now you need to know what.
More than likely it is HG as its the back near the water jacket.
Old 08-04-2016, 09:01 PM
I don't think it is at the water jacket because I am not loosing any coolant
When I had it running it I could hear a puff or a pop from around #8.
I read somewhere that might be and indication of the cam being ground down.
Old 08-04-2016, 10:28 PM
abran's Avatar
A leak down test would tell you if it's an exhaust valve, intake valve, or going into the coolant.
The valves could point to a cam lobe.
Old 08-05-2016, 03:57 AM
Ideally I would be looking for a very maximum of 10% lower than than the highest test pressure. Check the RAVE spec for the test design pressure also.
IMO it could be piston rings but I would put my money on valve seating correctly. If only rings were worn and losing pressure evenly the whole test would be similar. IMO it's more likely a coked up valve or bad valve seating caused by a bent valve stem or even a loose valve seat. In any event the heads need to come off so it's worth testing the valves and new stem seals fitted.
Old 08-05-2016, 08:46 AM
I will start the disassembly this weekend. Any thoughts either way on using ARP studs?
Old 08-06-2016, 04:50 AM
ARP bolts are good provided they come at the right price, but ensure they are genuine not fakes. TIP: I always liberally greased (just a smear of grease) the bolt stems with high melting point white grease to avoid seizures between the alloy head and bolt. Ensure you follow the bolt/tightening torquing procedure correctly (checkout the RAVE Manual).
Fit new gaskets everywhere especially head gaskets. Victor Reinz HG's are good to go.
Old 08-07-2016, 10:44 AM
shanechevelle's Avatar
Did you prop the throttle body open?
Did you crank the engine the same amount of times on each cylinder?
There are wrong ways to do a pressure test.
Old 08-07-2016, 11:31 AM
Yes and No I'm not sure I have heard of having the TB open as being critical (that is not meant as an arrogant response I just remember only handful of conversations about it)
Old 08-07-2016, 01:30 PM
How does the engine suck in the air needed to get a good reading with the flap closed?
Quick Reply: My compression test results 😔
