My DI needs some help
Old Dec 23, 2009 | 02:46 PM
Disco-Nate's Avatar
Default My DI needs some help
I have a DI with 138100 on it, this morning i changed the oil with synth 10W-30, new oil filter (the one that is twice the regular size). While I was letting the oil drain I started checking the spark plugs because I have been having a continuing problem with a left bank misfire (code 40), I pulled out all the plugs and they ALL have huge carbon build ups (totally black, had to scrape with a wire brush) and also found that the #6 is somewhat cross threaded. using bosch 4+ and STI wires
My question is this: what should I do next to get the misfire issue under control, plugs wires and cap are new. am I running to rich? O2 sensors need replaced? induction clean? sea foam? am using only premium and a few tanks ago used STP injector cleaner.
anything i can do about the cross thread?
also how do you clear a code on an OBD I truck?
Old Dec 23, 2009 | 05:40 PM
tweakrover's Avatar
the code clearing is easy, under the passenger kick panel there is a white and orange wire connetor, turn the key up to the second click, unplug the connector for 5 sec. plug it back in , turn off key , wait for the main relay to click under the dash and you're done.
Old Dec 23, 2009 | 06:29 PM
hilltoppersx's Avatar
start with a tune up.
ljdiscovery
Nov 9, 2012 06:15 AM
Fivespddisco
Off Topic
Dec 5, 2009 09:56 PM
dms98e
Mar 24, 2008 02:19 PM
Gtown_rover
Feb 26, 2008 11:52 AM
cushionhead
Dec 11, 2006 07:52 PM
