My disco died...
Old Oct 30, 2018 | 09:03 AM
x2c.diamundz's Avatar
4wd High
Default My disco died...
So today on my way to work, my battery light blinked on and I lost power steering. I got to work and when I parked, I noticed the engine had smoke pouring out of it and there was coolant all over the engine bay and on the ground. Any ideas? I got to work when it was dark and I haven't had time to really look at it yet so I don't know what it could be. Help would be appreciated, thank you .
Old Oct 30, 2018 | 09:36 AM
mln01's Avatar
Sounds likely to me that the serpentine belt broke, which would explain the battery light, loss of power steering, and the truck quickly overheating. What you saw was likely steam, not smoke. Check all the pulleys to see if any of them seized and caused the belt to fail. If the pulleys are all good, install a new belt, top up the coolant, and move on. The serp belt failed on my truck a little over a year ago, for no apparent reason, and the symptoms were the same as you describe.
Old Oct 30, 2018 | 09:40 AM
Frtpilot's Avatar
Default Check these items
First check your serpentine belt. Battery light, and loss of power steering indicate the belt may have broken. In regards to the coolant issue, the broken belt may have damaged your hose? Or, it could be an issue similar to my experience where the water pump seized and snapped my belt? Next question would be to investigate whether the water pump turns or is seized. Replace the belt, charge the battery, check hoses, refill coolant, and go down to your local auto store and borrow a test kit to check if you have a blown head gasket. After my mishap, I had to replace the head gaskets. Good luck!
Old Oct 30, 2018 | 07:42 PM
4wd High
Thanks for the help guys, I was able to look it over and it's definitely a water pump failure; the battery light/power steering loss is because of the coolant spraying everywhere and is getting on the belt causing it to slip (as the light wasn't always on, it would turn on and off and power steering would come and go) how unfortunate for this to happen the day before my vacation ��
Old Nov 2, 2018 | 06:18 AM
shanechevelle's Avatar
Heres what happened.
your belt broke.
loss all power, power steering and cooling.
you should have pulled over because you also overheated your truck perhaps damaging it.
Old Nov 2, 2018 | 05:07 PM
Llamasayswhat's Avatar
your belt broke.
What are you talking about? The belt is still on the vehicle and wasn't thrown off or broken. His water pump has failed and is pissing coolant on the belt causing it to slip.
Old Nov 3, 2018 | 08:32 AM
oops. I didnt read the whole thread. Happens when you're in a rush.
Gestun
Aug 23, 2018 11:35 AM
Greatpyr
Nov 14, 2013 07:04 PM
undertaker
Dec 26, 2008 04:30 PM
PDXDisco
Jun 8, 2008 09:39 AM
hriant88
Apr 19, 2008 09:27 AM
