No power steering
Old Nov 11, 2013 | 08:09 PM
Greatpyr's Avatar
Default No power steering
Changed serpentine belt because of whining noise , noise gone drove less than 20 miles , now power steering stopped , belt is on correct with ace diagram all pulleys are turning no leaks and fluid is at level and churning.. Any thoughts ...
Old Nov 12, 2013 | 06:13 AM
coors's Avatar
You did confirm The power steering fluid is bubbling inside the reservoir with the engine running?
Old Nov 12, 2013 | 09:14 AM
Jared9220's Avatar
This is just a shot in the dark but,
An engine belt has groves on one side and is smooth on the other. They can get flipped inside out from people playing with them and if you install them like that it could cause the belt not to grip the pulleys.
Also, The spring in the tension pulley may have got messed up when you pulled it back to take the old belt off and put the new belt back on. As a result it may not be holding good tension on the belt causing it slip and not turn the PS pump.
Old Nov 12, 2013 | 07:19 PM
Greatpyr's Avatar
Yes bubbling in reservior and belt smooth side out ,wil look@ pulley as all were turning, but not sur how much tension, thanks for reply , it's always something,but its a rover not a cruiser
Old Nov 14, 2013 | 07:04 PM
Greatpyr's Avatar
Update .. No gurgling no bubbling in reservoir, is pump bad?
johnnyjohnny
Sep 26, 2019 09:37 PM
DiscoBritney
Dec 19, 2011 06:24 PM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
jycsalas
Apr 17, 2009 02:21 AM
