No power steering at low RPM
Old Aug 22, 2018 | 09:58 PM
Gestun's Avatar
6th Gear
Default No power steering at low RPM
Hello all. I have been the proud owner of an 04 disco (120K, 4.6 V8) for almost a week and I'm looking for some guidance with a power steering issue. i dont have any power assist until engine is above 1100RPM then it works as expected. Reservoir is topped off and fluid looks good. There might be some seepage around the high pressure fitting on the PS pump but i also have and oil leak that might be causing that residue. The belt feels tight and looks good, Should my first step be replacing the pump?
Old Aug 22, 2018 | 10:04 PM
CollieRover's Avatar
It could be your belt tensioner. How old is it?
Also, are you 100% that your belt is routed correctly?
Old Aug 22, 2018 | 10:28 PM
Gestun's Avatar
6th Gear
Not sure on the age. is there a way to test them. Ill verify on the routing but i am pretty sure its correct
Old Aug 22, 2018 | 10:45 PM
Gestun's Avatar
6th Gear
Ok i checked the routing and it was good. however when i look at the belt i noticed a couple cracks. If I press on the belt between the tensioner and the alternator i get about 1/2 inch deflection. So maybe a new belt first?
Old Aug 22, 2018 | 11:46 PM
Saturnine's Avatar
Probably a good idea
Old Aug 23, 2018 | 11:35 AM
shanechevelle's Avatar
Belt it's probably not, but if it has cracks, a new one is a good idea.
ps pump
then ps box.
hopefully one of them changes it.
try changing the fluid...sometimes the po might have put the wrong fluid in or has never changed it.
Carlos Man
Jan 8, 2023 12:03 PM
MadScientist
Apr 12, 2021 09:37 PM
Greatpyr
Nov 14, 2013 07:04 PM
ogden45
Dec 28, 2011 08:50 AM
PDXDisco
Jun 8, 2008 09:39 AM
