My engines blown? Is it true? Please help!
Old May 9, 2011 | 10:42 AM
Originally Posted by Lannes
Hi all,
I'm a brand new member and I need some help - any advice would be appreciated. My disco kept over heating and leaking coolant, (2003 SE, all options). After a few trips to the mechanic, they now say that the sleeves inside the block have ridden up and are allowing coolant to run through the engine. Bottom line - the engine's toast, or I have to buy a new block, which would bascially cost the same amount as getting another engine. I spoke w/ another dealer in Harrisburg, they confirmed that it's true... all after only 75k miles!
So...my question to you, o wise land rover fans, is this legit? What else can be done? She's not worth putting a new engine in... but I don't want to let her go! Any advice would be much appreciated, or just a shove in the best direction to start finding the parts I need. I'm a semi poor mechanic at best, so please be gentle with the responses!
Thanks all - with you help, maybe we can get her back into the mudd!
- Lannes
First, you better be ready for a large expense, one that you caused by not dealing with it right away.
Second, how did they determine the sleveves are the issue, have they removed the head or are they guessing?
Old May 9, 2011 | 06:31 PM
Lannes's Avatar
4th Gear
Thanks for the great feedback guys. I'm going to get in touch w/ some folks and I'm gonna see what can be done.
Thanks again for the help!
Old May 9, 2011 | 06:33 PM
Lannes's Avatar
4th Gear
They are guessing and I've spoken to another dealer and they've said the same. Do you think it may just be the gasket?? Should I pay them to pull it apart and take a look? I guess at this point I don't have much choice too....
thanks for helping a noob!
Old May 9, 2011 | 08:20 PM
Bundu's Avatar
Banned
If you let them do it they will take you for a ride... just my 2c.
Old May 10, 2011 | 09:36 AM
dcarr1971's Avatar
"...Harrisburg..."? Are you in central PA? I'd get it out of the dealerships and over to a good independent Rover mechanic.
If you're central/eastern PA, I'd try to give Trevor at RoverLabs Rover Lab Services a call.
Old May 10, 2011 | 09:43 AM
There is no way they can say for sure you have a sleeve issue. Yes you may have one, but if you don't have them at least pull the heads, you may be throwing away a perfecticly good engine.
EL GALLO
Nov 18, 2007 09:56 PM
whiteROVER98
Jul 31, 2007 10:37 AM
Camdisco24
Apr 22, 2007 12:37 PM
mr.47
Dec 14, 2006 11:06 PM
surf9ska
Feb 14, 2006 03:52 PM
