My luck ran dry...as is my wallet
![Thumbs down](https://landroverforums.com/forum/images/icons/icon13.gif)
I got stuck in traffic near the Ohio State campus today. They're doing all kinds of stupid construction, and I got wedged into one lane with all kinds of potholes and craters, and giant holes in the road. No problem. Well, it wasn't a problem until I hit a particularly large one which jarred the whole truck pretty bad...and triggered a flashing ECM. The exact same problem as before, and the exact same symptoms. So there is something physically loose or broken in my ECM.
While I can genuinely say I'm not surprised, I am a little disappointed. That being said, I had a couple of questions.
When I took it to the shop, and they gave me the quote for the ECM, there were three things on the list.
The ECM of course - $1700
Labor - $89.95
Programming the ECM - $99.95
That raises a question in my head: Why do they need to program the ECM? I figured it's a plug and play thing.
But that raises an even bigger question in my head:If I were to get my hands on a used ECM (for much cheaper than $1700), would it need to be programmed?
Labor - $89.95
I would make sure the connector on the ECM is plugged in tight before you lay out money for an ECM. I could be wrong but since the problem went away after they unplugged the connector and plugged it back in then the problem came back when you hit a hole I think it's a loose connection rather than a problem in the ECM. Take a long zip and wrap it around the ECM and connector to keep pressure and see if that makes any difference. I really don't think you have a major problem.
Of course, what do I know? LOL
Is the ECM the silver thing that is mounted on the passenger side inside the truck?
This may help a little more. This was copied from RAVE
The engine control module (ECM) is located on the RH side A post below the face panel inside the vehicle. It has a
cast aluminium case and is mounted on a bracket. The ECM has 5 independent connectors totalling 134 pins.
Dude come on. if you had to replace an ECU every time you hit a bump in an actual roadway i don't think they would use the damn things for a camel trophy event. With a rover and any other car for that matter start really small. I learned really fast that most people are so quick to tell you to replace all of this goofy **** on your car and half the time it's something that takes one hour and five bucks to fix.
