My luck ran dry...as is my wallet
Old Apr 24, 2009 | 05:28 PM
tornado_735's Avatar
Thumbs down My luck ran dry...as is my wallet
I got stuck in traffic near the Ohio State campus today. They're doing all kinds of stupid construction, and I got wedged into one lane with all kinds of potholes and craters, and giant holes in the road. No problem. Well, it wasn't a problem until I hit a particularly large one which jarred the whole truck pretty bad...and triggered a flashing ECM. The exact same problem as before, and the exact same symptoms. So there is something physically loose or broken in my ECM.
While I can genuinely say I'm not surprised, I am a little disappointed. That being said, I had a couple of questions.
When I took it to the shop, and they gave me the quote for the ECM, there were three things on the list.
The ECM of course - $1700
Labor - $89.95
Programming the ECM - $99.95
That raises a question in my head: Why do they need to program the ECM? I figured it's a plug and play thing.
But that raises an even bigger question in my head:If I were to get my hands on a used ECM (for much cheaper than $1700), would it need to be programmed?
Old Apr 24, 2009 | 05:36 PM
AK Rover's Avatar
I would make sure the connector on the ECM is plugged in tight before you lay out money for an ECM. I could be wrong but since the problem went away after they unplugged the connector and plugged it back in then the problem came back when you hit a hole I think it's a loose connection rather than a problem in the ECM. Take a long zip and wrap it around the ECM and connector to keep pressure and see if that makes any difference. I really don't think you have a major problem.
Of course, what do I know? LOL
Old Apr 24, 2009 | 05:39 PM
That's a good idea AK...
Is the ECM the silver thing that is mounted on the passenger side inside the truck?
Old Apr 24, 2009 | 05:44 PM
You know what I should do is call the city, and tell them that the road broke my truck, and have them fix it LOL!
AK Rover's Avatar
Do you have the RAVE manual? If not click on the link in my signature and download it. It is a life saver.
Yes, the ECM is on the passenger side, more than likely behind the glove box. It's hard to tell exactly from the picture in RAVE.
Old Apr 24, 2009 | 05:46 PM
AK Rover's Avatar
This may help a little more. This was copied from RAVE
The engine control module (ECM) is located on the RH side A post below the face panel inside the vehicle. It has a
cast aluminium case and is mounted on a bracket. The ECM has 5 independent connectors totalling 134 pins.
Old Apr 24, 2009 | 06:12 PM
I did have a disc but I don't know where it is. I clicked to download it and it opened in firefox. Found the fuel injector connector.
Old Apr 24, 2009 | 07:13 PM
khuds308's Avatar
Dude come on. if you had to replace an ECU every time you hit a bump in an actual roadway i don't think they would use the damn things for a camel trophy event. With a rover and any other car for that matter start really small. I learned really fast that most people are so quick to tell you to replace all of this goofy **** on your car and half the time it's something that takes one hour and five bucks to fix.
Old Apr 24, 2009 | 07:33 PM
Yo, check my new thread...
Last edited by tornado_735; Apr 25, 2009 at 12:37 PM. Reason: not annoyed anymore.
jpluncford21
May 21, 2011 06:19 PM
aussiedg87
May 4, 2011 08:05 AM
discotruck
Sep 20, 2009 07:51 PM
supremei
Aug 8, 2009 03:41 PM
MEP
Nov 29, 2005 12:22 PM
