Is my starter going bad?
Old Apr 7, 2008 | 03:13 AM
Phototone's Avatar
Default Is my starter going bad?
1994 Disco 1, 5 sp. manual transmission. Starter spins the engine just fine when cold, engine starts right up. When the engine is warm, starter is very sluggish, cranking slowly, but engine still fires right up. I am assuming this is probably a "draggy" starter that needs replaced? I have a brand new fresh, high amp battery.
Old Apr 7, 2008 | 08:28 AM
Default RE: Is my starter going bad?
Go down to your local auto parts store, have them run a load test on the battery/alternator and a drw test on the starter to see how many amps it is pulling.
Most likely a bad battery.
Old Apr 7, 2008 | 09:07 AM
Phototone's Avatar
ORIGINAL: Disco Mike
Well, I thought it was the battery, so I replaced the battery, and there is no change in the starter behavior. I did this before I posted my question.
Old Apr 7, 2008 | 12:01 PM
Then go have a starter draw test done.
Gimebakmybulits
Jul 14, 2014 05:57 PM
TATZOO
Jun 10, 2013 05:22 PM
johnkbl
Apr 23, 2012 07:49 PM
Carl082974
Dec 4, 2010 11:10 AM
Sunshine
May 12, 2008 08:25 PM
