Is my tranny (or T case) about to go boom?
Old Nov 19, 2022 | 05:33 PM
longtallsally's Avatar
Default Is my tranny (or T case) about to go boom?
This is a pretty healthy clunk that seems to have just started. I’ve done a tranny service and it’s not leaking. The U joints and flex disc in the rear are in good shape and I recently changed the oil and greased the front shaft. I’ve also recently changed the fluid in the diffs.
With winter coming and the barn not being done yet, I sure hope the T case isn’t nuked. It was supposedly changed prior to my purchase.
And sorry I can’t fully imbed the video, so you’ll have to click the link.
https://photos.smugmug.com/Cars/Land..._8905-1280.mp4
Old Nov 19, 2022 | 05:59 PM
Extinct's Avatar
Yikes, that is not good. Almost assuredly tcase. I would check the center shaft, I bought one where the nut on the center shaft had come off and the shaft backed out. Try shifting the tcase in to low or shifting the CDL in to locked and see if it still does it.
Old Nov 19, 2022 | 08:17 PM
I just took it for a spin around the property and did 4 low, 4 high, CDL, etc, even got the TC going and it didn’t do it at all or (at least didn’t seem to) feel strange.
As I’ve been struggling with P0501, I’ve wondered if they goofed the T case install.
How would I check the center shaft?
Old Nov 19, 2022 | 10:18 PM
I pulled out the T case manual. Is it the nut inside of 22 in this pic that you are referring to?
Old Nov 20, 2022 | 05:50 AM
Extinct's Avatar
No, it's the nut on 19. You can see it from under the truck, backside. Given that it stopped when you shifted it I think you did not have it all the way in gear.
Old Nov 20, 2022 | 09:44 AM
Ah that makes sense. I’ll go out and check it here in a minute.
Someone from a failbook group thinks it could be something in the valve body denoting wear?
Old Nov 20, 2022 | 01:03 PM
That nut is tight, so I’m good there. I’ve not changed the fluid in the T case yet, so I might try that too.
I just started it and gave it a go and it was back to being perfect. I think I’m going to check the tray fluid too just as a matter of course.
cburns
Jan 8, 2015 06:12 AM
FlyingZebra34
Jul 23, 2012 09:09 PM
jm12503
Nov 27, 2008 06:08 AM
m1943
Aug 6, 2007 05:56 PM
Doak
Nov 27, 2006 11:54 AM
