tranny
Old Nov 23, 2006 | 10:17 PM
Doak's Avatar
Default tranny
where do i check my tranny fluid level and what kind of tranny fluid do i put in my 00 disco 2
Old Nov 24, 2006 | 11:04 AM
Default RE: tranny
How many miles on your truck, is the tranny leaking?
To check the level, you will have to crawl under the truck and slowly remove the tranny fill plug on the side of the tranny oil pan, don't take it all the way out, just far enough to see if fluid will flow out if the plug is removed.
If oil flows out, the tranny is full, if not you need to add some dextron. If it is low and hasn't been changed in 25,000 miles or so, just service it instead.
Mike
Old Nov 27, 2006 | 09:03 AM
Doak's Avatar
Default RE: tranny
yeah i ended up servicing it but i had never seen a sealed transission before.
Old Nov 27, 2006 | 11:54 AM
Default RE: tranny
ORIGINAL: Doak
Did you recheck the fluid after the sevice and you drove it?
If not, check it again, you may still need to add some more.
Mike
LiftedRover96
Feb 11, 2006 01:46 PM
r1dad
Nov 12, 2005 12:19 AM
Bene
Oct 27, 2005 03:30 PM
Bene
Oct 26, 2005 11:17 PM
Bene
Jul 10, 2005 09:42 PM
