Is my Transmission shot..?
Tips.
1. There is alot to be said for a lack of lubrication. PB blaster is your best friend. use liberally on subframe bolts.
2. Check your flex plate while you are in there.
3. Now would be a good time to replace your rear main seal. Would suck for you to have to remove the new trans in another 6 months.
Also I big one that will cost you a ton of money, make sure the converter is seated.
I have seen this so many time I cant even remember, the converter go in turns and then goes in again.
So, so many times people fill the converter and then stuff it on and think is home, only to truck the truck a wipe out the splines on the front pump.
the result is replacing the front pump or having to buy another used tranny.
I forgot about that one.
