Is my WATER PUMP bad?
Old 05-31-2014 | 09:16 AM
Jared9220's Avatar
Originally Posted by masterseung
I was a bit low on gas and had the front on ramps. I was low but it wasn't on empty, the light wasn't on.
I did not remove spark plug wires. I checked the wires and the spark plugs and noticed that spark plugs #3 and #5 seemed a bit wet.
I am losing coolant (currently just water). I don't see any leaks but I am having to refill about a half inch in the morning.
Sigh... I fear it is a cracked head or block.
If you are not seeing coolant leaking on the ground then I would check the oil to see if it is mixing with water.
A bad reservoir cap can cause the expansion tank to over flow but you would see coolant underneath it on the floor.
You may have to get the UV dye for the cooling system to help find your leak.
  #52
Old 05-31-2014 | 03:02 PM
masterseung's Avatar
Ok, last night drove it kinda hard, parked it and noticed the coolant level was about half inch lower than before I topped up coolant level (with just water) so I am assuming that I am losing coolant.
This morning I went to fill it back up to the line and when I tried to open the expansion tank cap, it was pressured a lot and when I released all the pressure, the level came back to normal....
  #53
Old 05-31-2014 | 03:13 PM
This is with engine cold, 80F outside, it was 70F when I topped it last.
  #54
Old 06-01-2014 | 09:57 PM
RicketyTick's Avatar
Yeah, returning the GMB water pump. Went to Autozone and picked up their lifetime warranty water pump.
I wanted to put the old one back in, but upon close inspection, I can tell the bearings are worn so I just went ahead and replaced it.
So, the new pump with the brass impeller is the one you bought from autozone with a lifetime warranty? Does it say Airtex on the box or pump?
  #55
Old 06-02-2014 | 11:15 AM
jamestfl's Avatar
hmph, I'm not seeing one at AutoZone with the brass impeller? and the one with the alum impeller w/ lifetime warranty is about $190. could you clarify your purchase for us, thanks!
  #56
Old 06-02-2014 | 03:08 PM
Yeah, I got that one from Autozone. I'm not sure but it has this print on it that the stock one had except instead of "A-01" it said "A-02". Here is a pic of the old one, couldn't get a shot of the new one since its already on the car.
This is the one I got, it had brass impeller. Duralast.
  #57
Old 06-05-2014 | 09:25 AM
Cool! Looks like it's an Airtex and $169 with a lifetime warranty is better than $149 plus shipping for a 2 year warranty for sure.
So how did you come out? did you get your problem fixed?
  #58
Old 06-05-2014 | 05:41 PM
Jared9220's Avatar
I do believe he found a crack in his block.
  #59
Old 06-05-2014 | 07:39 PM
Bummer! That's what I'm afraid I may find when I get mine back together, even though I cold pressure tested to 60 lbs. Won't know until I fire it up I guess.
  #60
Old 06-05-2014 | 08:21 PM
It's either the block or the head... not sure if there is any way to tell..
Yep, looking for an engine..
Quick Reply: Is my WATER PUMP bad?
