Mysterious Leak
Old May 11, 2009 | 05:54 PM
kfox77's Avatar
Default Mysterious Leak
I have a 00 with 115K on the clock and as I was changing the brakes this last weekend I noticed a leak coming from... I am power washing it this afternoon and will report back. The fluid was oily and clear to a very light brown. The small puddle was under the middle of the truck under a cross member and the differential, I think. Any thoughts would be very appreciated.
Thanks,
Kelly
Old May 11, 2009 | 06:06 PM
Well being oily and a clear brown is either engine oil or gear lube.
Rub it between your fingers and see how viscous it is, a heavy thick oil will be gear lube, a light thin oil will be engine oil.
Old May 12, 2009 | 05:06 AM
AK Rover's Avatar
It sounds like gear lube from the transfer case to me from the description of where it is.
Old May 12, 2009 | 10:53 AM
kfox77's Avatar
In further looking it is coming from the flat plate just above the cross bar. I am assuming this is the transfer case. Is this a fix I can do on my own or do I need to take it in and have it repaired? I am fairly inclined to do most of this stuff as long as it does not take 8 hours. Anything else I should look for or replace while I am there?
DiscoHan
Sep 16, 2014 11:03 AM
wallyman424
Dec 13, 2012 11:14 AM
tgwaldop
May 14, 2009 01:28 PM
westminster04
May 13, 2009 09:55 PM
DiscOwner
Mar 25, 2005 03:55 PM
