Mystery hose connect
Old Sep 3, 2019 | 04:08 PM
zuke's Avatar
Default Mystery hose connect
So I put the Hyundai purge control valve on and the unit on top of it has 2 barbs for vac hoses
I don't have a spare truck around to look at. Anybody know where these go to?
Old Sep 3, 2019 | 05:30 PM
Rlozano's Avatar
You should see a loom that has vacuum lines. The loom splits between the charcoal canister by the abs and goes across the engine to the intake where the other vaccum lines enter on the passenger side. I've never opened up the loom so I can't be certain exactly where they go. Still at work so I can't snap a photo but I hope this starts pointing you in the right direction.
Old Sep 3, 2019 | 05:36 PM
Best4x4's Avatar
SAI solenoid = little black valve with the nipples. It goes from the nipple on the intake to the valve and then to each SAI stack located on each bank.
Old Sep 3, 2019 | 06:11 PM
zuke's Avatar
That explains it. I pulled that sai junk off during a motor swap.
Thanks
Old Sep 3, 2019 | 08:26 PM
Best4x4's Avatar
No problem at all!
sanderjoems7
Nov 5, 2019 04:44 PM
kuau
Jan 26, 2019 07:15 PM
Disc James
Jun 29, 2014 05:25 PM
srockrae
Jun 24, 2014 10:45 PM
Fast951
Apr 18, 2014 02:12 PM
