Mystery Water leak
Old Oct 23, 2013 | 01:35 PM
jimpty's Avatar
Default Mystery Water leak
I have a water leak....1st lemme tell what its not
not heads or water pump or thermostat or intake heater
it is dripping from the drivers side front bumper just about where the tow hook access is about 1 foot behind it..... I cannot find it
Old Oct 23, 2013 | 01:56 PM
ZGPhoto's Avatar
Bottom of radiator?
Old Oct 23, 2013 | 02:24 PM
dusty1's Avatar
are you sure it's coolant? washer jet hoses, not squirting there?
my guess is with Zack, if so. look to see if it is chasing on the bottom of the lower hose.
you can get some dye additive junk to use with a black light or pressure test
Old Oct 23, 2013 | 04:55 PM
jfall's Avatar
pull off the cover to the radiator..
Two screws.
The little plastic hose may be broken or breaking / cracked.
The holes that you took the screws out of could be leaking too.
Replace the radiator -
Nissens $210 or so shipped from RockAuto Parts Catalog
Old Oct 24, 2013 | 01:15 AM
land o lake's Avatar
3rd Gear
The hose is 53 dollars + tax.
Old Oct 24, 2013 | 07:29 AM
drowssap's Avatar
pressure test your cooling system, why guess.
dida
Mar 5, 2011 05:41 PM
EstorilM
Feb 22, 2010 12:20 PM
XR4Tim
Freelander
Dec 30, 2008 02:07 PM
mac25dm
Jan 21, 2008 08:21 AM
skipbrakes
Nov 5, 2007 07:36 PM
