Name those gaskets
Old May 23, 2018 | 08:59 PM
shanechevelle's Avatar
Default Name those gaskets
Finally redoing the head gaskets on my rover.
I found the part that failed. It wasnt the liners. They look fine.
The gasket cracked right where the coolant passes through.
I circled some gaskets in the kit...I cant remember where they all go.
Can you help?
Thanks.
Attached Thumbnails Name those gaskets-20180523_193829_007.jpg   Name those gaskets-20180523_215542.jpg
Old May 23, 2018 | 09:56 PM
CollieRover's Avatar
  • the rectangle with the holes opposit each other is for the plenum.
Old May 23, 2018 | 09:59 PM
Alex_M's Avatar
The square with the circle hole is the throttle body.
Old May 24, 2018 | 02:24 AM
Ok. I believe the one is for the oil pump.
There's copper rings that I cant figure out.
earlyrover
Apr 10, 2017 09:25 AM
01d2Jeff
Jan 30, 2012 10:18 AM
RROJ
Mar 26, 2011 02:37 PM
Jawbox
May 19, 2006 02:44 PM
05LandRover
Off Topic
Mar 29, 2005 05:37 PM
