Neapco or Precision U joints and Centering ball?
Old Dec 15, 2012 | 08:08 PM
CANAMDiscovery's Avatar
Default Neapco or Precision U joints and Centering ball?
Is there a preference...
... or is it one of those 6 of one, half dozen of another?
the way I understand it is.
Neapco 7-0081NG centering kit
Neapco PDQ 1005 U joint.
OR
Precision 344 u joint
Precision 617 centering ball kit
I believe the joints in my shaft are Neapco...grease fittings on the ends. One of them has "made in the USA" on the end.
Removed the shaft today, locked CDL, test drove...the chirping noise is no longer here...I guess that means drive shaft.
My joints seems good with no play and are still nice and smooth. I assume the centering ball is at fault here.
Attached Thumbnails Neapco or Precision U joints and Centering ball?-img_0209.jpg   Neapco or Precision U joints and Centering ball?-img_0211.jpg
Old Dec 15, 2012 | 08:55 PM
I used the 344 and 617's for my truck.
Old Dec 15, 2012 | 09:25 PM
Colorado David's Avatar
If you are rebuilding an original equipment prop shaft the u-joints will be the 1300 series (Neapco 1-0005.) I don't know about all aftermarket prop shafts, but my Tom Woods prop shaft uses the larger 1310 series (Neapco 1-0154.) If you don't know, I would measure before buying. A u-joint can be bad and start making noise before showing signs of being loose. I'd replace everything while you have it off the truck.
Last edited by Colorado David; Dec 15, 2012 at 09:28 PM. Reason: additional information
Old Dec 15, 2012 | 09:37 PM
hilltoppersx's Avatar
Take the precision numbers to a local drive line shop and get the Spicer parts.
Old Dec 16, 2012 | 02:31 AM
antichrist's Avatar
The Spicer 5-4x are NLA.
You can get Hardy-Spicer from some Rover parts places.
I've used both Precision & Neapco. I like the zerks on the end caps for easier greasing.
Old Dec 16, 2012 | 06:32 AM
Wow! I did not know that Tom, thanks.
Old Dec 16, 2012 | 12:23 PM
Default Slip Joint Boot
It is a BRD brand joint cover with a large crack.
At this point I think I will go to O'reillys and see if they have it.
Unless there is something I am missing online?
I guess I could head over to a local driveline place and I would assume they have it in stock?
Thanks for the input...
No press or or bench vise...not looking forward to doing this job. I am thinking the ole hammer and socket method (heard it called the THOR method) is not going to be easy.
Attached Thumbnails Neapco or Precision U joints and Centering ball?-img_0212.jpg
Paul Grant
Oct 4, 2014 08:27 AM
jw928
Feb 28, 2009 10:26 PM
holly5
Jan 31, 2009 03:55 PM
holly5
Jan 24, 2009 12:28 PM
Night Train
Nov 28, 2008 11:17 AM
