Need a 4.6 Block.Please
Old Jan 3, 2011 | 02:51 PM
s928s's Avatar
Default Need a 4.6 Block.Please
Anyone have a 4.6 block for sale..Rebuilt my current motor, new cam and bearings. 200 miles later the cam is locked up and has to come apart again.
any help or leads will be welcome.
Thanks in advance, David
Old Jan 3, 2011 | 02:52 PM
NiteTrain's Avatar
http://www.roverlandparts.com/discovery-engine.aspx
Old Jan 3, 2011 | 04:45 PM
David,
Engine are real expensive to ship, better find a local yard.
Old Jan 3, 2011 | 09:42 PM
bosshogt's Avatar
I have 4.6L block for sale. I am presure testing it this week to confirm its integrity. It came out of a 2004 that I parted out with 39k on it. It was hot pressure washed and cleaned by my machine shop and visually inspected. I am making rubber seals to go over the water jacket openings to pressure test it. Like a bike tire would be tested in a sink full of water. No bubbles at 40lbs of pressure = no leaks/cracks. This is the same method my machine shop was going to perform but they did not have the correct rubber covers for the water hole openings to place on top of the block and it would not fit in their cage to immerse it in the water bath. Once I have presure tested it I will leave the seals on it so the buyer can verify it themselves before they start to build it.
04 03 Discovery II 4.6 V8 Engine Block Honed Hot Dipped
$949.00
330505555989
Old Jan 3, 2011 | 09:53 PM
bbolin's Avatar
Hey David
Where are you located? I have a 04 long block with 72K. The block is together with the heads off. If you are not to far geographically we can talk.
Brooke
humroot
Jul 22, 2019 06:33 PM
Noble Six
Jun 4, 2014 04:51 AM
Blakesrover
Feb 21, 2013 01:43 AM
2001SE7
Mar 23, 2011 04:20 PM
JBEGIN
Jun 27, 2009 12:38 PM
