Need advice.
Old Apr 5, 2021 | 08:27 AM
whowa004's Avatar
Then you should be totally fine with just removing the rear. Now if you struggle to get out of the trail with just 2wd is a potential different problem depending on how tough of a trail it was..
Old Apr 5, 2021 | 11:39 AM
CaptainAaron's Avatar
I've been in nearly your same situation. I blew the rear diff in the middle of nowhere. One of the pins actually started to go through the top outside part of the diff housing. I took off the rear driveshaft and limped it out with the center diff locked. Luckily I was with a friend with a Defender that towed me through a couple of rough bits on the way back when I only had front wheel drive. Rear gears/axles made bad noises the whole way home - probably 20 miles or so - but I made it. Replaced the entire rear axle assembly with a used unit. Planning on getting an Ashcroft locker soon.
Old May 9, 2021 | 07:43 PM
Black.Rhino's Avatar
I figured I'd update this thread. My rear differential ring and pinion are fine. It was just my wheel hub bearing assembly that disintegrated. Removed and replaced just waiting on a proper torque wrench to hit the 362-ft pounds necessary. The plan is to replace the remaining three along with making sure all my ABS wires are hooked up.
I have a tendency to consider the worst case scenario rather than taking it from the simplest onward. Thanks for all your help, It's a great forum.
Old May 9, 2021 | 10:59 PM
Richard Gallant's Avatar
@Black.Rhino Thanks for the update
Old May 10, 2021 | 02:00 AM
The Deputy's Avatar
Running over sized tires like that is very, very stressful on hubs. So, spend the extra money on quality brand.
Old May 10, 2021 | 02:23 AM
Good advice. I bought 2 hubs from Atlantic British not sure they're the highest quality? Planning on down sizing from 37's to 35's since I agree too much stress on everything.
Brandon318
Feb 16, 2020 10:03 AM
hankeester
Feb 6, 2014 05:34 PM
honda50r
Mar 20, 2012 11:11 PM
IDAHODISCO
Feb 27, 2009 09:40 PM
discokauai
Jun 23, 2008 09:24 AM
