Need Advice
Old Apr 9, 2012 | 03:32 PM
Zonk872's Avatar
Default Need Advice
Exhaust pipe is cut over axle and needs to be extended due to Emissions test in N.C. having moved here recently. What is the trick to cutting a hole in the rear fender? What tools are needed to make a clean look?
Thanks
Old Apr 9, 2012 | 07:36 PM
I wouldn't suggest it, you tail pipe will move around too much and vibrate in any hole you cut in the fender panel.
Old Apr 9, 2012 | 09:23 PM
Why not just have the tailpipe extended?
Should only cost like $20.
D2 side exhaust? - Land Rover Forums : Land Rover and Range Rover Forum
nateandnikki
Jul 2, 2013 06:38 AM
cushionhead
Aug 14, 2006 06:31 PM
RovinLA
Sep 20, 2005 02:06 AM
basquiat
Jun 8, 2005 12:17 AM
steveo
Jun 6, 2005 03:03 PM
