need advice ASAP on 02 disco
Old Aug 13, 2009 | 09:55 AM
tct2h's Avatar
Default need advice ASAP on 02 disco
I have a 02 disco II SE 7 with 127000 miles. i wrecked front awhile ago and has created several leaks, including slight oil leak and having to refill radiator reservoir with water at least once a week. recently, the transmission started slipping between 2nd and 3rd gear. also, when idol there is a strong exhaust odor as well as the entire vehicle shaking. had it looked at and mechanic said the rear main seal was broken and the diagnostic shows transmission slipping. he did not do any work and suggested i get rid of it... he said it would cost at least $300 to take the motor out to fix rear main seal and noted that it was not worth it with transmission issues. please advise with any thoughts or ideas.
Old Aug 13, 2009 | 11:02 AM
You do have some problems, worse yet, you'll have a hard time selling it is as is. If you want to send me your number, I'll walk you thru what needs to be done.
taylorm334
Jun 14, 2013 08:07 PM
Denalipilot
Defender
Apr 25, 2012 10:10 PM
morzy41
May 25, 2010 07:18 PM
vada9
Aug 25, 2008 09:21 PM
Brad S1
Jun 28, 2006 03:25 PM
