Need Advice On Leaking Rear Differential
Old Jun 10, 2020 | 02:37 AM
Brandon318's Avatar
Originally Posted by Kalliste80
Update: I'm having a terrible time removing the axle nuts on the rear end I got from the junk yard. A rear end sitting on the ground doesn't give the same leverage to turn the axle nuts as the one on my disco. All i want off it at this point is the rear diff. Is there any way to remove the rear diff from the rear end without taking the axle nut and axle shafts? I'm thinking a cutting disc is the only way but looking for other suggestions before I have to buy one. Thanks in advance!
I’m concerned that you’re saying axle nut...there is no nut that needs removing. There are four bolts that go into the back of the hub that hold it onto the hub carrier. Remove the four bolts, not the axle nut.
Old Jun 10, 2020 | 07:28 AM
Kalliste80's Avatar
Thanks Brandon, very insightful! I'm glad I left the rear end alone over the last couple days. This will be much easier to deal with now.
Old Apr 10, 2022 | 01:57 PM
EricG.'s Avatar
3rd Gear
I have a 1970 S2A and the rear differential's housing (the pumpkin) is rusted through at the top and is leaking. My mechanic says he can fix it by grinding off the rust and completely cover the diff housing with JB Weld steel epoxy. I have had great luck with JB Weld and although it sounds like it might be worth a try for this application but I would gladly welcome any suggestions or relatable experiences such as this one.
Old Apr 10, 2022 | 02:31 PM
Harvlr's Avatar
Hi Eric. You’re posting in the Disco section. There is a Series section of this forum. I’m pretty sure JB Weld will work for a while but probably not a good long term fix.
Kalel
Aug 2, 2011 11:26 AM
discoboy
May 9, 2011 09:25 PM
aemnky606
May 28, 2010 06:40 PM
navysar
Dec 24, 2008 07:08 PM
Classic89
Sep 3, 2007 09:04 PM
