Need the collective wisdom of the forum elders.
I had a chevy truck throw a ring gear tooth once, immediately started whining like crazy. Bought a non-driving disco once where the middle shaft in the transfer case had the retaining ring come off and the shaft walked out until the gears were grinding I would check your differential fluids as well as the transfer case fluid, check the rear diff flex joint. If none of that checks out drop your diffs one at a time and check the gear conditions.
The following 3 users liked this post by Ben Matheson:
